Old 10-03-2013, 12:08 AM   #121 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
Very rarely when you press the middle button it does not alter the brightness, and showed the same sequence that shows when pressing the left.
I think I have this bug fixed by now. Try the new code, and tell me your results.
Why not use a system of 3 or 5 buttons, but with a different operation, stop using the buttons on the left, middle and right, and move to using a (top), (bottom), (OK), (yes) and (no).
The operation would be to (top) advance the menu to (bottom) retreat, and (OK) defined the choice, in some menus might be used (yes) and (no) to confirm the choice.
How would you handle entering numbers?
The results I got were:
Without pressing any button the result was: 03FF
Pressing the left: 02BC and 02BD or 02BE
Pressing the middle button: 034D or 034E and 034F
Precionando right: 03A2 or 03A3 and 03A4
Pressing the extra1: 03D3 or 03D4 and 03D2
Extra 2 still have no results.
Hm. The code shows that 0x02BC-0x02BE should generate a value corresponding to the right button, not the left. Similarly, 0x03A2-0x03A4 should correspond to the left button, not the right one. That might could just be an error that was based on what I posted earlier. Otherwise, the numbers look right.
