Old 10-04-2013, 01:11 AM   #16 (permalink)
Xist
Originally Posted by jeff88 View Post
Xist, what do you mean compare the tires to the template? Are you talking about the lack of levelness between the front and rear tire? I can see that the bottom of the front tire and the template match up, whereas the rear wheel is lower than the template. I'll have to check to see if I have a photo program that can rotate it a matter of degrees, not 90* or 180* only.
I'm kinda excited about doing the kamm with the spoiler attachments. I'm thinking about using an aluminum strip as the main mount. I am considering using a plastic strip from TAP plastics as well. Anybody have any suggestions?
I use Gimp, it is free, although I use Paint more. The Win8 Paint has more features, just like WordPad, but neither can take the place of real programs.
However, it would be faster for you to post the original picture and I will adjust it for you.
At least until I close Gimp!
For some reason, it seems to take a full minute to load! This is a nice, fast, and new computer, too!
