Originally Posted by Ardent
Almost. Now it has an upper-right bevel.
*headdesk*
Edit: Finally kicked the butt of the incorrect upper right segment for the number "7" of the spiffy number font. Changed the code to correctly support the left analog button as the 2k2 resistor, and the right analog button as the 10k resistor. Changed the Parallax 5-position code to match. Added an ASCII diagram to show how to wire up and connect the Parallax 5-position switch.
(current MPGuino code version is at first post of this thread)
