Originally Posted by t vago
Changed the code to correctly support the left analog button as the 2k2 resistor, and the right analog button as the 10k resistor. Changed the Parallax 5-position code to match. Added an ASCII diagram to show how to wire up and connect the Parallax 5-position switch.
Hope I'm not causing any inconvenience to the left and right buttons, for me it is not important yet, because I still have everything so provisionally.
That's mainly a matter of figuring out what keypresses would go to what actions. I can do that, but it's not a high priority right now.
This system I just gave an idea, because it seems to be a more practical working, I think the current very confusing, and at the same time one can eliminate the simultaneous buttons, which may create some difficulties, due to a resistance value proximate of another.
Thank you
José Rodrigues
