Old 10-04-2013, 02:21 PM   #31 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I've been using the Mobil 1 0w-20 in my Civic which also calls for 5w-30. The only issue I'm having is the oil filter won't hold the oil overnight. I've tried Mobil 1, Bosch and Denso filters. The oil light stays on for a few seconds after starting. Each filter came off the engine completely empty.
As far as oil pressure while running is concerned, I can brake in gear until the engine is shaking and bucking. The oil light stays off. It's the alternator light that will flicker when I do that. 208k miles on this engine.
I did top off the oil this summer with a quart of 0w-30 for a little extra protection since I don't have an oil pressure gauge.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
wmjinman (10-04-2013)
