Old 10-04-2013, 07:41 PM   #135 (permalink)
josemapiro
Originally Posted by t vago View Post
I do not understand. Do you mean that the resistances, which are internal to the Parallax board, should be shown? I left them out so as not to cause confusion.
In a previous post you said you had to remove the internal resistances, but then said it could also keep the internal resistances, I just wanted to know if keeps or removed, does not need to show just wanted to know.
I do not understand. What should the CTR be?
I asked because I do not know if it was your fault, or if it was intentional, you have (middle) button clearcut to be used with the (up) the Parallax board.
Thank you
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
t vago (10-04-2013)
