Old 10-04-2013, 09:09 PM   #1 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Airflow at front plate
I searched for tuft tests, tunnel tests on here and on Google, without much luck.
Looking for how the air flows around the front plate. The reason I'm asking is I'm thinking about using one of my spare 80"s gm flip down plate holders in the front. If you flip this around, the closing spring will hold the plate cracked slightly open (opening at bottom). My opening in the grill block is directly behind this area currently. The idea is to use the air pressure at higher speeds to push the plate back, and closing the gap. If the air moves upwards more than it pushes back or to the side/bottom, then this won't work. This will be on my civic vx . Anyone have any thoughts, or just try it?
Shooting for 600 miles of range at 65-70 mph out of a vx.
