Old 10-05-2013, 06:51 AM   #36 (permalink)
freebeard
My trailer-hitch-in-progress has two downward pointing ears for the safety chains to pass through. I'd thought about adding a steering damper that would be positioned just under the hitch.
There is a category of 'load-leveling' or 'equalizing' hitches you might want to look into.
I also saw someone suggested running with the trailer tire half-flat. Sort of a real primitive air suspension with no unsprung weight? You could compare aired up with load against empty with low pressure.
BamZipPow (10-05-2013)
