Yep, check out the installation images and you will see what I am talking about first hand. At least my way you by pass all the expense of a static bearing and additional hardware ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
