Old 10-06-2013, 02:10 PM   #2 (permalink)
UltArc
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
I'd be worried about chloroplast decomposing. The heat may make it catch on fire if it gets too hot and too dry.
Every vehicle is different. I first started by making a simple design that would easily come off if something went wrong, it was weakly attached, and easy to get to from the dirt on the side of the road. I also started in stages, first the front, then middle, then rear.
I would not advise starting at the rear, since if it is sealed, it may act like a parachute when air moves above the belly pan. Sealing it upwards seems like a lot of extra work compared to just starting from the front.
I would advise using polycarbonate (election sign material, basically thin plastic in the same design as cardboard).
These threads may help you develop a plan more so, often as we who have done it forget lots of things from when we make threads, and go into great detail- you may learn things there that we forget to bring up now.
belly pan - Google Search
or
underbody - Google Search
Look forward to following your build.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
