Old 10-06-2013, 05:47 PM   #146 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Ardent View Post
Additional Data:
This morning after start-up and while on the Instant/Tank screen, things looked normal until beginning to back out. As soon as movement began (VSS pulse), iM went from "0.00" to "----". Stopping resulted in the display returning to "0.00". Resuming motion in the forward direction iM again went to dashes but as soon as I pressed the accelerator iM began displaying good values.
This afternoon, before resetting a decel-accel induced glitch I switched to the Instrument screen and rpm was "----" too.
Strange. It sounds like the fuel injector input isn't seeing anything to speak of, for those moments that "----" shows up. Can you revert to the old 0.86 code, and see if that behavior still shows up ("999999" instead of "----")? My fuel injector interrupt routine might be misbehaving (as it uses only one pin, instead of the 2 pins that the 0.86 code used).
Also, can you give me your microseconds/gallon number and your VSS pulse/mile number?
