Old 10-06-2013, 05:50 PM   #147 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
The simultaneous buttons, are present following result.
Left + Middle -> 3 btn pressed
Middle + Right -> 6 btn pressed
Left + Middle + Right -> 7 btn pressed
Left + Right -> Goes to contrast
Extra# 2 -> 16 btn pressed
The result is correct, or should have a different outcome?
That behavior sounds correct.
Hold down the left + middle buttons for over 1 second, and it should reset the tank trip. Similarly, holding down the right + middle buttons for over 1 second should reset the current trip. This was a feature I added early on, because I wanted to have a kind of a failsafe against inadvertently resetting the current/tank trip data.
