Originally Posted by t vago
That behavior sounds correct.
Hold down the left + middle buttons for over 1 second, and it should reset the tank trip. Similarly, holding down the right + middle buttons for over 1 second should reset the current trip. This was a feature I added early on, because I wanted to have a kind of a failsafe against inadvertently resetting the current/tank trip data.
Have tested the buttons and functions as described.
Now I have to test the car to see if it works.
Thank you
José Rodrigues
