Old 10-06-2013, 07:41 PM   #150 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Ardent View Post
I'll give the old code a try.
8226 PPM
247804090 usec/gal.
I just had a thought - My injector interrupt routine has two separate rationality checks to ensure that the injector pulse being read is actually a valid pulse. The two checks reject pulses that are either too long or too short. It could be that your idle and just-off-idle pulses are being characterized as being "too short," thus being rejected. That would certainly cause what you're seeing.
Can you tell me approximately what RPMs you're seeing when the "----" occurs?
