Old 10-07-2013, 10:43 AM   #31 (permalink)
Miller88
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
As long as it's a load range E tire, you will sacrifice no load carrying capability by going to a 215 85R16 tire, for example. That may give you a slight increase in fuel economy.
What about doing the PS pump on an AC clutch? Turn it off when you don't need it?
Being a 3/4 ton, it probably has a TTB front suspension right? If it has the beam axle, that would make it easy to do a belly pan. Even if not, you should be able to make one that bolts to the frame for most of the truck.
