Old 10-07-2013, 10:41 AM   #4 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Sam Powell View Post
Thanks.If I understand you correctly, you are envisioning attaching something to the rear, and not the car body.
Nope, everything gets fitted to the underside of the car.
Or (partly) on the rear axle.
See drawing ... nobody's going to hire me as a designer I'm afraid
Both of these areas are acting as parachutes now.
Doing away with this parachuting is a good part of the improvement you get with a belly pan
The aim of a belly pan is to improve upon a vey bad flow situation underneath a car.
Fitting a partial belly pan aft, doesn't help much as the airflow that reaches it has already gone bad.
Fitting a partial belly pan under the front does help as it delays the flow going bad.
There is a guy who shows up with a 64 VW beetle regularly, and I was especially interested in the bottom of that car. It is completely flat. It is about as flat as you could imagine the underside of a car being.
It's all about re-inventing the wheel ...
Car manufacturers have long known what they can do to improve aerodynamics.
It's about time they start doing it again ...
