Old 10-07-2013, 06:49 PM   #11 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
You've got the right sensor, and the right ECU. It's the wiring. The stock harness for that car didn't have 5 wires for the O2 sensor. The OBD0>>OBD1 jumper harness you bought probably isn't designed for a 5 wire O2 sensor either. Find a service manual pinout for the P07 ECU, and find where the 5 wires from the O2 sensor connect. Check continuity from the O2 sensor connector (engine bay) to the ECU connector. Do this for all 5 O2 wires, and make sure all wires are going to the correct pins on the ECU.
1998 Honda Civic HX - My Project Thread
The Following User Says Thank You to cbaber For This Useful Post:
nitebluesky (10-08-2013)
