Originally Posted by cbaber
That is true, but the ideal solution is a smooth belly pan front to rear. An air dam increases the frontal area of the vehicle. If it does divert air away from under the car it can increase efficiency, but a full belly pan will be more efficient.
Well said, I forgot about frontal area. Thank you for clarifying!
