Old 10-08-2013, 05:04 AM   #38 (permalink)
E.Roy
fuel conserver
Civic - '99 Honda Civic EX
^^^ The small vacuum leak would raise your idle though, which should consume more fuel. Thanks for posting your TPS and LOD values.
I should clarify when I said I left the TPS connector off on the '90 Camry it was by accident, and the car would shift absurdly early, but it did let me realize the ECU relied on TPS voltage to control shift points.
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
