Yup, another difference is the aftermarket header is only in one cylinder tube in the header. The original vx sensor reads gas coming from all 4 cylinders. Not sure if that's a problem but worth noting. I may be able to get you a manifold and converter but you will most likely have to change the mid pipe goin from the new converter to the intermediate pipe.
I have like 4 extra vx manifolds but the converter is harder to find. But I know where one is.
Burn lean and prosper \\ //
