Old 10-08-2013, 06:47 AM   #39 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by PaleMelanesian View Post
The trouble is an automatic won't allow that combination. It holds a lower gear to higher rpm instead of allowing such open throttle.
And if you briefly lift the throttle , get it to shift up, then get on the gas again (staying short of kick down) ?
Friend of mine is driving his 3L BMW X3 diesel with 8 speed ZF auto to 5 L/100km , that's 47mpg, taking it easy but not really hypermiling it .
The ZF shifts up very quickly if you don't really floor it - and with a 3L TD engine with heaps of torque, low rpm is no issue at all.
Did you go along on the Audi X-country run with CleanMPG BTW ?
