Old 10-08-2013, 11:05 AM   #162 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Ardent View Post
The only behavioral difference noted was that from Key-OFF to Key-ON the back-light would illuminate with the 0.86 code, but not 1.86.
It's enough. If I understand you correctly, you're saying that with DCB's code, your backlight came on, and with my code, it did not. That means that DCB's code is responding to your engine starting, while mine is not. That sounds repeatable, which is progress.
If you don't mind, I'd like to experiment on you... heh, on your setup, anyway. I am going to comment out the bits in the 1.86 code, that relate to the two rationality checks, then send the modified code to you for testing. Depending on your feedback, I am then going to progressively un-comment each bit, and then send the code back to you for further testing. It should not take much more than 4 or 5 tries.
You up for that?
