Old 10-08-2013, 12:13 PM   #163 (permalink)
Ardent
Originally Posted by t vago View Post
It's enough. If I understand you correctly,. . . That means that DCB's code is responding to your engine starting, while mine is not.
Not quite. This was with the key ON; before advancing to the START position. Both were responding this morning when the engine started.
Edit: I'm guessing that there was a small INJ or VSS pulse sent when the ECU powered up.
If you don't mind, I'd like to experiment on you... heh, on your setup, anyway. I am going to comment out the bits in the 1.86 code, that relate to the two rationality checks, then send the modified code to you for testing. Depending on your feedback, I am then going to progressively un-comment each bit, and then send the code back to you for further testing. It should not take much more than 4 or 5 tries.
You up for that?
I'm up for testing.
