Old 10-08-2013, 05:20 PM   #166 (permalink)
josemapiro
Originally Posted by t vago View Post
Okay... Those are simple buffer circuits. They would certainly work, but my opinion is, is that it's over-engineering the circuit.
One would get the same benefit, merely by changing out the 100k resistors for 47k resistors (or even 22k resistors).
Ok, I thought it was better with the use of transistors to protect the board.
I need help configuring MPGuino, what is the function of each of these lines and where do I find these values​​.
Contrast
Metric 1-Yes
InjTrg 0-Dn 1-Up
Tank (L)*1000
Inj Delay (uS)
Revs/Inj Pulse
Min Good RPM
VSS Pulses/km
VSS Delay (ms)
Mass} (kg)
FrArea*1000 m^2
C(d) * 1000
C(rr) * 1000
Microsec/L
Timeout (s)
Scratchpad(odo?)
Thank you
José Rodrigues
