Old 06-29-2008, 05:08 AM   #20 (permalink)
willow70
I allways thought warm air into a carb was to combat carb icing,when warm air is selected on a light aircraft the idle rpm drops by 100 or so.I would have thought if you lived in a dry warm area warm air would not be needed. I experimented on a 1988 ford
and fitted manual cold/warm air selected by a switch in the car.The situation may be different on a more modern car where it may be designed to compensate for differing air temps.
