Old 10-08-2013, 09:46 PM   #43 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by E.Roy View Post
^^^ The small vacuum leak would raise your idle though, which should consume more fuel.
Unless you hooked your controlled vacuum leak up through a 12V vacuum switch that you could turn on and off with a switch.
Just saying....
