Old 10-09-2013, 06:20 AM   #8 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by jeff88 View Post
I would say that members here would gladly accept a 5% increase in power/efficiency
So a bleed valve won't work, but what about a device like the transducer in the first post, which is designed to only put out the appropriate amount of air, no more and no less.
Hi Jeff,
I'll take any 5% improvements I can get.
Here is the cut away view of your transducer. That part: Supply Valve (at the bottom) is a throttle.
This is a miniature version with 1/4 inch air flow fittings, rated at something like 4.5 scfm at 25 psig. You might look into how much air an engine sucks in at cruise.
-mort
