Old 10-09-2013, 03:34 PM   #11 (permalink)
ProDarwin
Originally Posted by davelobi View Post
Anyone ever beat this high idle at higher vehicle speed?
I made a IAC blockoff for Saturns quite a while ago. I sold a bunch on sixthsphere.com, and I also gave the drawings to someone else to make more. There are a few floating around on there if you want to pick one up.
The main reason I made it was so the car was way less annoying to shift - RPM drops like it should when you let off the gas and clutch in.
Also, given that you are in Michigan, you could run the car with an MS, or OBD-1 swap the car and tune the OBD1 computer.
