Old 10-09-2013, 04:22 PM   #12 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by low&slow View Post
I do need to work on filling the gap between the trunk and my back to eliminate the resulting turbulence. I'm thinking some foam attached to the front cover. I'll post some pix after I make it.
If there's a gap between you and the trunk, better fill it up.
If it's not filled all the time, rounding off the front (along the edges) will also help a bit.
Rounding off all straight edges on the trunk would help - except at the rear, that's where you'd want a sharp separation.
Take a look at the vetter streamlined zero motorcycle if you haven't already
They're using some sort of foam on the front of the tail and behind the rider's legs.
