Old 10-10-2013, 03:41 PM   #17 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Even if you end up needing the seat, it comes out and goes in with 4xM12 [14mm head] bolts, and literally takes longer to get the seat back into the car than it does to line it up and bolt it in place. I typically only use the two that are on the front of the hinge, so I don't even have to tip the seat up to remove it.
The Following User Says Thank You to Christ For This Useful Post:
paintme205 (10-16-2013)
