Thread: Oil grade data.
Old 10-11-2013, 11:00 AM   #7 (permalink)
E.Roy
fuel conserver
Civic - '99 Honda Civic EX
Originally Posted by SentraSE-R View Post
I don't think you should be running such thin oil in such an old engine. Toyota's TSB EG018-06 recommends 5W-20W in certain '06 engines, and 0W-20W only in the '06 and newer 2AZ-FE engine used in the Camry, Solara, Highlander, and RAV-4. It specifically says not to run those thinner oils in older engines.
I'm ok with it for these reasons:
1) I trust Toyota engines longevity
2) I read the Oil Manufacturers Data Sheets to make my decision on viscosity
3) The colder temps have set in here in Buffalo
4) you get a bad feeling when you turn the key when it's 0 deg F in January
5) I currently have less than $800 into the car including tax, title, reg
6) I think you can choose an oil for your needs, race cars need thick oil due to heat, hyper milers barely tax their engine
As Sean says:
Originally Posted by Sean.Heihn View Post
....There is no difference between 0w-20 and 5w-20 at operating temp, the 0w is thinner than the 5w cold, but all oil is substantially thicker cold than at temp.
Also, just based on the oil viscosity data, the thread starters claim is reasonable knowing the oil is less thick, and that Auto makers are using thinner oils
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
