Old 10-11-2013, 12:53 PM   #29 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Thank you for your advice, unfortunately when I switched to my smaller tires it dropped the car back down 3/4”, and it would be too tight to still fit a 2+” opening and a radiused lip in within the remaining area without impacting my approach angles and ground clearance.
I updated my drawing, with my new plan of having my radiator intake at the very bottom of the grill opening, probably about 2.5-3” tall and 25” wide, so I will be close to the 1/6 “ideal” ratio. I picked up a flexible silicone baking mat, to actually form the seal between the front end “duct” and the radiator. I am still planning on using coroplast to make the duct, but I may reuse my aluminum front belly pan piece for the bottom, since I already have it made. (It is nowhere near exhaust….)
The Following User Says Thank You to aardvarcus For This Useful Post:
aerohead (10-11-2013)
