time was taken into account. One thing noted was past ~2/3 manifold pressure (%66) the amount of increase in acceleration was insignificant assuming shifts were at same RPM. i will post some time logs later when i get home. car is automatic but the triptronic system was used to shift at desired RPM.
UPDATE ---
I can't find the numbers for the load testing under 2500rpm, but here are the numbers for when the car is left in fully automatic D (drive).
RPM--MPG--Load--Acceleration
1800--23.5-60--- 38s
2500--22---70---36
3000--22---80---34
4000--19.1--95-- 32
I have also been advised by several subaru members that variable valve lift system could play a role in improving swirl (BSFC) at low RPM and moderate loads. I'm not sure how this works but it's apparently very similar to honda's 3-cylinder vtec engine, where it has multiple sweet spots along the powerband (1500-4000rpm).
MORE DATA ---
to 60kmh and coast to end of 350m runway:
8.1lhk ~2200rpm 39s 65% Drive
9.4lhk ~2200rpm 40s 65% tiptronic
9.1lhk ~2500rpm 43s 70% tiptronic
11.8hjk ~3600rpm 36s 90% tiptronic
10.1lhk ~3600rpm 40s 80% tiptronic
0 to 70km/h
60% 18.1lhk 20s ~2000rpm
70% 23.2lhk 16s ~2200rpm -> 28% more fuel vs. 60%load but only 20% faster
85% 35.7lhk 11s ~2500rpm -> 53% more fuel vs 70%load but only 40% faster
