Old 10-11-2013, 10:52 PM   #31 (permalink)
Sam Powell
How are the screens fastened in? I would be inclined to remove those and use them as templates for sheet material of some kind, and then put the solid pieces back in with the the same mounting system used for the screen. I would fill the upper one and the two side ones completely, and then block of the sides of the lower center one.
I use a hand held jig saw to cut panels for my fabrications. If you are using aluminum, then put a hack saw blade in. If using plastic use a very course cut blade.
Good luck on this project. I love that model Celica. It is unabashedly Japanese, and does not try to be German or American. For this reason I think it is a true expression of the designers artistic nature. At least in the East Coast it does not get the attention I think it deserves.
Sam
