Old 10-11-2013, 10:05 PM   #54 (permalink)
Occasionally6
I did a quick check using the assumption that the cycle is adiabatic, air only as working fluid. Yep, pressure at end of expansion stroke is much greater than that at the end of the compression stroke.
