Solution to starting 307 PAS
You connect the big black wire to plus, big colored wired to negative and from the 9pin connector 5 and 9 to positive to get it going. Tried it on mine (building an electric Citroen Xsara at kWsara dot com) and it works. I got the info from here: hr-ev dot blogspot dot com. Can't post proper URLs yet.
