Old 10-13-2013, 05:03 PM   #23 (permalink)
ps2fixer
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Yea it is kind of odd it is 5 lug, but all 4 tires are the same so it seems it must be factory, it is 2wd as well, both of the 4x4 ones are 6 lug.
I don't really see a real point in duals on a small truck, I don't think it would benefit much unless you were already overloading the truck and needed a little extra support. Not like the stopping power is any better unless you upgraded the brakes lol.
Know of any tricks to get the door to open up, I can't really tell exactly what is going on, but everything moves like normal, door handle is free, inner handle works fine, lock I can pull up and it seems to go up all the way, but when I pull one of the door handles it pulls back down. The key even works, but on the unlock side it is a bit restrictive, I worked with it for a few mins and didn't seem to get any progress on it. I guess I should probably just pull the panel off, lube it all up and work with it more.
