10-13-2013, 05:59 PM
#24 (permalink)
Ecomodest
The Van - '97 Chevy Astro AWD cargo van 90 day: 14.03 mpg (US)
Originally Posted by ps2fixer
Know of any tricks to get the door to open up, I can't really tell exactly what is going on, but everything moves like normal, door handle is free, inner handle works fine, lock I can pull up and it seems to go up all the way, but when I pull one of the door handles it pulls back down. The key even works, but on the unlock side it is a bit restrictive, I worked with it for a few mins and didn't seem to get any progress on it. I guess I should probably just pull the panel off, lube it all up and work with it more.
You might have a broken handle or a rod popped off. You may have to roll the window down and go at the mechanism with a coat hanger to get it open.
Being a mad scientist is not as easy as it looks on TV
