Old 10-14-2013, 11:07 AM   #194 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Ardent View Post
The day ended up being 375 miles total with no glitches. I'm pleased; thanks for the good work t vago!
It's good to hear that the code worked correctly this time. Looks like it was a mistake to move the injector interrupt code onto a single pin.
Originally Posted by AndrzejM View Post
First part of my trip behind me. I'm in Prague and MPGuino works flawlessly. I just need to get used to it because it's different from previous version I was using. I'm just not familiar with all the button combinations and all the letters describing values yet.
Yah, I got to work on documentation. Maybe I can convince the powers-that-be here to give me a Wiki page for the new-and-improved MPGuino.
The metric bug you described in the 0.86 code was indeed due to modifying the original code to work with 20 MHz processors, and not updating every single time-dependent line of code. That was one of the first things I overhauled, and I tested the bejeezus out of it to make sure it'd work correctly on 16 MHz and 20 MHz processors.
More to come after fill up and calibrating new setup.
Anyway good job t_vago!
Thank you! Looking forward to more of your feedback!
Originally Posted by Quezacotl View Post
Would'nt it be best that the text would scroll in the settings? Then there would be enough room to write it clearly instead of 16 char limit.
That might could be a good idea, too. It wouldn't take too much effort to set up.
