Originally Posted by t vago
Yah, I got to work on documentation. Maybe I can convince the powers-that-be here to give me a Wiki page for the new-and-improved MPGuino.
That would be great.
The metric bug you described in the 0.86 code was indeed due to modifying the original code to work with 20 MHz processors, and not updating every single time-dependent line of code. That was one of the first things I overhauled, and I tested the bejeezus out of it to make sure it'd work correctly on 16 MHz and 20 MHz processors.
And it works as it should! Good job!
And driving here I got this idea that I could use your code for measuring pressure to get temerature reading from the engine. I was working on that with "canadian" code but haven't finished that yet. So I need to start again with 1.86tav code
Could you provide the diagram how you actually connected MPGuino to the MAP sensor? Thanks
