A semi serious search for a rear axle with the same bolt pattern turned up the late 80's, early 90's Isuzu Pick up as having a 4 x 100 bolt pattern. Can anyone confirm that for me and perhaps enlighten me on the rear end gear ration of that vehicle?
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
