Old 10-15-2013, 04:51 PM   #19 (permalink)
aerohead
effect
Originally Posted by E.Roy View Post
Could it be the C111 appears narrow, which if true means it has less frontal area? Maybe frontal area to length ratio has an effect.
Yes,very much so.It's the plan-view corollary to the side elevation effective fineness ratio.
Kamm and Koenig-Fachsenfeld devoted quite a bit of wind tunnel model studies to quantify the effects of the L/WXH ratio for both Jaray-form,and K-form car bodies.
How the body cross-section varies along the longitudinal axis,to and from the position of maximum cross-section is critical also.
Fast pelagic fish are a good model for streamlining.Their frontal area occurs in the first 1/3rd of their body length and the last 2/3rds cleans up the disturbance.
