Old 10-16-2013, 12:30 AM   #196 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by AndrzejM View Post
And driving here I got this idea that I could use your code for measuring pressure to get temerature reading from the engine. I was working on that with "canadian" code but haven't finished that yet. So I need to start again with 1.86tav code Could you provide the diagram how you actually connected MPGuino to the MAP sensor? Thanks
The diagram has been folded into the code itself.
Also modified the code to make it easier to display things like the A-B display and the coastdown display, and added Arduino Mega 2560 support (which needs to be tested). The display modifications are slightly buggy right now, but should be fixed soon.
Last edited by t vago; 05-11-2014 at 04:27 PM.. Reason: current MPGuino code version is at first post of this thread
The Following User Says Thank You to t vago For This Useful Post:
josemapiro (10-16-2013)
