Old 10-16-2013, 01:18 AM   #51 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by E.Roy View Post
Could you also place a resistor inline in the voltage signal wire to the ECU, would that reduce voltage?
Nope.
A resistor inline with the signal wire will not reduce voltage, at least not reliably. However, a resistor between the signal wire and sensor common (ground) will by pulling the voltage towards ground. The best way to manipulate the signal voltage is to do this with a variable resistor so it can be fine tuned.
