Old 10-16-2013, 01:56 AM   #4 (permalink)
Occasionally6
Re. >=90% load. You can check that yourself.
If you pull up closed/open loop on the SCII screen that will tell you - with some inherent time lag in the display - when you are entering fuel enrichment i.e. entering open loop fuel control is the indication that extra fuel is being added.
Stay just short of that load. Up to that point, the higher the load the better.
The Following 2 Users Say Thank You to Occasionally6 For This Useful Post:
dmafanp (10-16-2013), SpindlyJim (10-18-2013)
