With the Prius I can cut the gasoline engine with pedal position, but it still pulls gas according to my UltraGauge, when travelling faster than 66 kph. Usually try to keep the mileage high while constant speed cruising, having given up on the PnG at highway speeds. Will try a test run, but with the changing temps we are getting in Sweden this time of year it is hard to do an accurate test, you never know how warm it is going to be two days running. Wondered if anyone else has attempted such a comparision in a Prius.
