When I say 1nzfe, I mean toyota echo/yaris/xa engine.
This engine would be a good fit for:
-corollas
-tercels
-paseos
-mk1 and mk3 mr2's
-Celica St's and 2001+celicas
It could also go into camrys and rav4's, but you would be fabricating all 4 mounts, and not just the one.
To my knowledge there is no RWD bellhousing that will work with the 1nz bellhousing pattern. You would be stuck making an adapter plate.
Just for raw fuel economy without the experimentation a 2nzfe in an early 90's tercel would be the ticket.....just don't wreck in it (that or there are 3cyl motors that probably fit). 2nzfe is the 1.3L version of the 1nzfe. 2nz's are also pretty cheap.
