Yap, carb is a donor from a "running" car. Pitted and weepy, but clean. Shaft play is good and the linkages, float, and jets that I can get at look good visually. I have another 1920 for spares. I'm positive its running rich idle circuit since I tried a warm air intake and it ran much better with the cold air replacement. Its a little sooty and loads up idling too. I wish I could do fuel cut coasting. I wish I'd kept the vapor recovery too. A 318 would be real nice, but I like the music the 6er makes loafing along at 45mph so much!
