Originally Posted by dremd
Solid advice.
I'll add, that it mostly applies automatics, manuals don't heat up as much.
Also all around checking out of vehicle is a good idea, adding a little stress+ load tends to bring out issues that wouldn't normally appear for a few thousand more miles.
True as when you are modding anything it is almost always best to err on the side of caution and this is one of those times depending on the size of your load and distance you need to move it.
