Even the line you are calling red is slightly above the cab in the middle. So I will be cutting below that to make it flush with the cab. From there I will be cutting diagonally down through whatever windows are in that path. I am sticking with the 12 degrees for best results. However it will probably be a straight diagonal line, iow no curve in the cut. Now I Need to buy a new angle grinder & start cutting.
Been thinking a lot about what to replace the top with. I wont know until I actually do it the way I am. I like the idea of having a top thats hard with hinges and lift supports.
